Orbi WiFi 7 RBE973
Reply
Orbi RBK50 blocks VOIP
csb1976
Follower
Hi,
I just switch to the Orbi RBK50 system and it is doing a great job. The only thing that doesn't work is a Cisco SPA112 VoIP solution. It seems that the Orbi blocks its access to the internet, so I can't register the SIP service. Does anyone have an idea?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
TrickyDick
Re: Orbi RBK50 blocks VOIP
You should check the ports required by your Cisco ATA to be port forwarded and them forward them to the internal IP address of your Cisco ATA.  Typically the ATA requires port 5060 forwarded to it.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3698 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
