Orbi WiFi 7 RBE973
Reply
Orbi RBK50 - issues with Skype and other remote video services
slavrenz
Is anyone else having issues with Skype, Teams, Zoom, etc. running very poorly with the Orbi Mesh Routers? With the stay-at-home measures over the last month, I've noticed frequent issues with poor bandwidth, pixelation, garbled voices, etc.
I realize there are about 1,000 different troubleshooting issues, and I won't detail everything I've done. But suffice it to say, I don't have speed issues with any other apps, I have a 100 Mbps+ connection to Comcast, and the quality of my line (jitter, SNR, etc.) is fine. I've also tried the Port Triggering options for these services to no avail.
I'm happy to entertain suggestions for troubleshooting, but mostly I'm looking to see if issues with Skype, etc. are a known issue with the current firmware (2.5.1.8). I've tried downgrading to an earlier firmware and re-upgrading, and that hasn't really fixed anything.
Message 1 of 5
Retired_Member
Not applicable
Re: Orbi RBK50 - issues with Skype and other remote video services
I don't think it's unique to any particular piece of software.  Numerous complaints about (2.5.1.8).
Revert back to the one that was most stable for you....or.....standby for dozens of useless questions that will only waste your time.
Message 2 of 5
Guru
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Are the problems see over wired and wireless connections?
Please try a factory reset and setup from scratch with the RBR and RBS.
Message 3 of 5
slavrenz
Yeah, that's what I was thinking...I've tried all the troubleshooting stuff. Sounds like I need to wait for a new firmware update
Message 4 of 5
Guru
Did you downgrade FW?
Be sure Circle or Armor isn't enabled. Circle has been causing problems lately.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1125 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
