Reply
Orbi RBK50
Walkingbear
Orbi RBK50
Question,  does the orbi RBK50-100NAS work with a DSL internet service like say Centurylink.?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Walkingbear
Re: Orbi RBK50
Ok, found my answer on page 14 of the manual.
Thanks
Message 2 of 3
Guru
Re: Orbi RBK50
Question is that if Orbi works with the modem. There are two types, modem only and modems with built in routers and wifi:
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Orbi systems work with most ISP services and modems or ONTs.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Router Mode |  Wifi Router CAX80 (Router Mode) and RBK963 (APMode) | and MK63 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 240 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
