- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK53 Satellite's Firmware won't update
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just installed my Orbi (2 satellite) system and everything is working perfectly. I went to update the firmware and it wouldn't autoupdate. I then looked on the discussion boards and found I could do it manually. The problem is the thread that I read mentioned nothing of updating the sats first, so I updated the router first with V1.4.0.34. Now, no matter what I try (based on the discussions) I am unable to update the sats. It keeps giving me a warning that says "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product." I downloaded a new .img file and it gave me the same warning. Any ideas on what to do now?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also updated my router first. I was able to update my satellite by navigating to the Web GUI on the satellite's IP and updating from there. Did you try that? You will need to determine the IP address of your satellites first. They are listed under attached devices on the router GUI.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK53 Satellite's Firmware won't update
You're sure your downloading the satellite file? It's not the same one that was used on the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks to both of you for your quick answers!
MarkC1024, I wasn't aware that there were different versions for the router and satellites, but I looked on Netgear and found a version for the satellites (I had to search for RBK53 whereas before I looked under RBR50 which showed up due to my model number). The odd thing was that it had the exact same file name, but I downloaded it anyway.
st_shaw, I was able to log into each individual satellite via your method and then using the new file I just downloaded, was able to successfully upload the file to both of them. They are now currently using the latest firmware. Thank you both for the great information! I really appreciate it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know how it worked out. Glad we could help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just posted a help request because I can't update the firmware on my satellite either. I have tried 6 times and each time it says incorrect or corrupt file. I read the instructions and have not updated the router first as I noted some did, but it still does not work. Just looking for some additional help. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having the same problem. I won't update either auto or manual. When I download what is supposed to be the latest firmware I get v1.11.0.20 In the auto update window it says latest version is v.1.12.0.18.
When I go to install what is available I am told it is incorrect file!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I finally found the right version on their website, though I don't remember how. 🙂 I also realized I needed to drag the .ing file out of the folder to the desktop. When I did that the manual update worked when I clicked on that file. Everything updated but it sure wasn't smooth or well explained. I am delighted with how well my home is now covered, so if it doesn't have any of the earlier glitches it is a keeper.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I take back what I said about the speed. Argh. Yesterday I was getting about 2/3 of wired speed in my kitchen, about 20 ft from the router. My old wirless router was lucky to get hald speed. I just did a speed test with the new firmware and am getting 1/3rd the ethernet speed. I will let it be for a while and see if things improve by tomorrow...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, back up to excellent wireless speed. Yeah! Here is the link to the newest firmware . https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
- Mark as New
- Bookmark
- Subscribe
- Permalink
FYI since just went thru firmware update thing for the first time and had issues. The reason you should update the Satellite(s) firmware first and then the Routers is that Satellites and Router cannot communicate if they are running different versions of firmware. So if you do the router first, then it won't see the satellites. But note, when you do the Satellites first, they will be lost to the Router UNTIL you update the firmware on the Router too. They all have to be running the same version to be sync'd. Hope this helps some - would have saved me a day and 1/2 if I'd known.
