Orbi WiFi 7 RBE973
Reply
Orbi RBK53 System Firmware Updates
WhatsUpperDude
Follower
I Just got the orbi system a couple monthes ago and its def. not up to date i have the  V1.4.0.18 but when i check it says  no new firmware but when i look anline it shows theres an update  however do i really have to update all these updates one at a time until i get to the current to get it updated Orbi-2.pngOrbi-1.pngOrbi-3.png
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 3
Mooose
Luminary
Re: Orbi RBK53 System Firmware Updates
I believe you can go straight to 2.2.1.212 and then upgrade to 2.3.0.32 from there. Try it.
Message 2 of 3
Guru
To get from 1.4.0.18 you FIRST needs too apply v2.0.0.74 to the Satellite(s) FIRST, then the RBR. Once both are at v74, then you need to apply v32 to the satellites FIRST. Then use v212 to upgrade the RBR, then finally apply v32 to the RBR lastly.
Do a factory reset after v32 is applied and setup from scratch.
Please use a wired PC connected to the RBR. Use IE11 or FF browsers for this process.
Download ALL FW files to your PC and unpack the .zip files.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 908 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
