Orbi WiFi 7 RBE973
Reply
Orbi RBK53 router replaces my old router?
Lexkok59
Guide
I just bought my new Orbi RBK53 system. Do i understand it correctly that the routerfunction is enough to protect me like a regular modem/router? Now i plugged the orbi router directly to my internet access and disabled my old router. Evertything just works fine, i was just curious for my security kind gegards Lex
Message 1 of 6
Accepted Solutions
Guru
Re: Orbi RBK53 router replaces my old router?
The RBR functions just a like a router. Not a modem as it doesn't have a built in modem.
Yes all Orbi routers include a firewall for protection.
Message 2 of 6
All Replies
Guru
Message 2 of 6
Lexkok59
Guide
Just for my good night sleep, if i read the manual they say i must connect my orbi router to my existing router, see picture.
But i do not have a router anymore and i juist directly plugged my glass internet cable in de internet connection on the orbi. Dus the orbi than have more than enough security?
Message 3 of 6
Guru
The RBR functions just a like a router. Not a modem as it doesn't have a built in modem. You would plug in the RBR into your ISP modem.
Message 4 of 6
Lexkok59
Guide
So the picture only is for if you have a modem, which i dont have
Message 5 of 6
Guru
If you have ISP services into a wall outlet, then you would connect the RBR there. Where ever your ISP has your service in your home.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 842 views
  • 6 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
