Orbi WiFi 7 RBE973
Reply
Orbi RBK53
Cbard
Follower
Orbi RBK53
I need to hardwire the two Satellites to the Orbi router. When I attached the satellitese with a lan cable the whole system locks up
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
SW_
Prodigy
Prodigy
Re: Orbi RBK53
Maybe things have changed recently, but before attaching LAN cable (wired backhaul), you have to setup backhaul via wireless first.  If you've already done that, please ignore this.
Message 2 of 3
Guru
Re: Orbi RBK53
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Be sure Daisy chain is disabled on the RBR.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 661 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
