Reply
Orbi RBK53
NAL
Follower
Follower
Orbi RBK53
Can I add another Orbi satellite to my recently installed RBK53? I want to purchase another Orbi satellite to go into my nearby annex which is 62 feet away from the new Orbi RKK53 router. Can anyone please recommend the Orbi satellite model I should buy RBK 50??
Thanks
Message 1 of 3
Accepted Solutions
Guru
Re: Orbi RBK53
Been some users mentioning having 6 RBS connected all at once.
Thanks
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 3 of 3
All Replies
Guru
Re: Orbi RBK53
Any of the satellites will work.
the benefit to the RBS50 is that is has a wider (higher throughput) backhaul.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
Guru
Re: Orbi RBK53
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 513 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
