P0606R's avatar
P0606R
Orbi RBR 20 and BT Homehub 6 BRS_wanlan_conflct in UK
Set up: BT Fibre 2 (full fibre network) > Cable to BT Home SmartHub 6 > Cable Orbi RBR20 (I've turned off wifi on BT SmartHub)
Firmware Version 2.5.1.16
I'm getting wifi all over the house but multiple BRS_wan_lan confilcts.
The advice I've read to fix it is to put Orbi in AP mode BUT one of the sites with the conflict is orbilogin.net so I cannot reach the settings.
Any suggestions?
Thank you.
  • FURRYe38's avatar
    IF the ISP Homehub has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Might try option #2 first...
    • P0606R's avatar
      P0606R
      Hi FURRYe38,
      Thanks for your suggestions.
      I think option 2 has to be the one but I don't know what it means. Sorry, non-tech!
      Option 3 won't work because I can't access orbilogin.net - I get the 404 error message (which I also get if I try to access the ISP's hub); and Option 1 won't because transparent bridge is not permitted on the ISP's hub.
      Now going to figure out how to do Option 2.
      P0606R
      • CrimpOn's avatar
        CrimpOn
        "orbilogin.net" is not a regular Domain Name, (such as netgear.com or facebook.com). The Orbi router intercepts this name (and several others) and returns the IP address of the router itself.  For this to work, the device seeking to connect to the Orbi has to be connect to the Orbi.
        Rather than use the "name", I prefer to open the Orbi web interface using the actual IP address of the Orbi.
        • If the Orbi is currently in "router" mode, then it will be giving out IP addresses to devices and one of the items it gives out is the "gateway" IP address, which is the Orbi router.
        • If you can access the BT router, there should be a table showing which IP address has been assigned to each device, and one of them will be the Orbi router.
        Hope this helps
