- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR 50 New firmware v2.0.0.74: Can you enable MU-MIMO, fast roaming and Beamforming now??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wondering if under the newest firmware v2.0.0.74, you can now enable Beamforming, MU-MIMO and fast roaming? Under the older firmware version, Netgear suggested unclicking those boxes to get the system to communicate with itself better. Trying to tweek more speed out of the wifi. Appreciate any input. Also, read somewhere, that with the newest firmware version, the orbi satellites can now communicate with each other to pass along connectivity to form a true "mesh" system? True, or does each satellite still only communicate with just the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR 50 New firmware v2.0.0.74: Can you enable MU-MIMO, fast roaming and Beamforming now??
My own experience has been that Orbi is OK with implicit beamforming (IB) and MU-MIMO (MM) "On", but my setup is better with both off. Your mileage may vary - I suggest experimenting and seeing what's best for you.
In my case, I don't any older wireless devices (i.e. non-ac) that would benefit from IB, so I generally haven't ever had that option enabled, outside of doing some gee-whiz testing.
I don't have multiple MM devices, so I wouldn't benefit from having that option checked, so I don't have it enabled.
As for Fast Transition (FT)... I tried that when it foist rolled out with the 2.0 firmware, but I experienced quite a few drops with my wifi-calling, so I now have the FT option unchecked too.
In my setup, most of my house has some overalp between my router and sat unit, so i think the having the FT option enabled just caused my iPhone to constantly jump between the router and sat. I'm fine with my phone being "sticky" with whatever unit (router or sat) it wants to be sticky with, so FT does more harm than good for me.
I don't have multiple sat units, so I have no interest in the new mesh option (that's the "Daisy Chain"option in Settings). I disabled that option, since it seems to be enabled by default.
But if you have multiple sat units that have problems connectimng using the current "star" topology, then the Daisy Chain (mesh) option is certainly worth trying.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good info. Thanks for the feedback. Hoping the daisy chain feature works, since want to buy another satellite [currently have 2] and it would be placed where it would have to connect to a satellite since it would be too far away from the router to be able to establish a connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
it works but its very sensitive to placement and you need to make sure its well out of range of the router or it will and can cause connectivity issues
eg there should be no wireless overlap from the router where you want to set the third sat
so like
sat -------- router --------- sat --------------sat
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have all of those options on with 25 or so devices connected, even older stuff and everything is working great.
A couple of Ring Doorbells, Wifi cameras around the house, WEMO devices, Computers, IPads, iPhones, Airplay, Synology NAS, TV, etc.. so all generations from b ot AC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i would be throwing out the wireless B devices though as it will be effecting all your other devices capability as the wifi is forced to work really badly with a B device connected
- Mark as New
- Bookmark
- Subscribe
- Permalink
@peteytesting wrote:i would be throwing out the wireless B devices though as it will be effecting all your other devices capability as the wifi is forced to work really badly with a B device connected
Working on that. fortunately most things I need speed on are on the 5 Ghz band.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Right after I enabled IB and fast roaming my system doesn't see one of my satellites; I have two and router. Wondering if there's something I need to do so the missing one returns. I just disabled both settings and still showing 1 satellite.
