Orbi WiFi 7 RBE973
Reply
Orbi RBR 50 - no download speed
LeifA
Apprentice
Hi!
When I installed a new 4G modem/router the function Test my speed in Orbi only tests upload speed, donwload stays at 0.0 (and ping is also 0.0).
Everything else seems to work as before and other speed tests that use the Orbi WiFi works fine.
Testing with Orbi speedtest gives me a better value for the incoming speed from the modem.
Any suggestions why?
Regards
Leif
Model: RBS50Y|High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite
Message 1 of 15
Accepted Solutions
Guru
Re: Orbi RBR 50 - no download speed
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@LeifA wrote:
Hi!
Regards
Leif
Message 4 of 15
All Replies
vajim
Master
Tell us about this 4G modem/router
you do realize that you can't run 2 routers without special configuration?
Message 2 of 15
LeifA
Apprentice
Yes, but I have problems with the bridge on the modem/router.
It can put one RJ45 port in bridgemode but when I use that port with Orbi in router mode Orbi will not connect to internet.
Now I have Orbi in AP mode on a normal port in the router/modem and then the problem above disappered.
Any suggestions on how to configure the Orbi on the bridge port?
The modem/router is Technicolor, Telia X2.
Leif
Message 3 of 15
Guru
Couple of options,
@LeifA wrote:
Hi!
Regards
Leif
Message 4 of 15
LeifA
Apprentice
Thanks everyone for the different suggestions!
I have tried to disable all wifi radios on the modem and configured AP mode on the Orbi router.
It seems to work fine now.
Regards
Leif
Message 5 of 15
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. Smiley Wink
Regards
Leif
Message 6 of 15
LeifA
Apprentice
Sadly, the same problem is back.
Orbi in AP mode, router wifi off.
Putting Orbi on router bridge port results in no internet on Orbi.
Leif
Message 7 of 15
Guru
I'd contact your ISP and have them help you ensure there modem is configured correctly and is working. If the RBR is in AP mode, it should get internet services from the ISP modem/router if using a good quality LAN cable.
Message 8 of 15
LeifA
Apprentice
Now I have removed the other router and is running my Orbi RBR 50 directly on the 4G modem, but the problem still persists.
The upload test in the Orbo app works fine but no download test is performed, it shows 0.00 on both my iPhone and iPad.
No problem with other speedtest.
Regards
Leif
Message 9 of 15
Guru
Sounds like something isn't configured right. I'd ask the ISP to help you ensure the modem is setup right, wfi radios are disabled and the Orbi is setup for AP mode.
Regards
Leif
Message 10 of 15
LeifA
Apprentice
Should the Orbi be in AP mode if it is used as the only router after the modem?
Leif
Message 11 of 15
Guru
IF your modem is in router mode, then Orbi should be in AP mode.
Leif
Message 12 of 15
LeifA
Apprentice
As far as I know the  modem is just a 4G modem, no router function.
I have removed the router thar was installed with the modem because that one could not be put in bridge mode. The ISP who supplies the 4G modem suggested that I connected the Orbi directly to their modem.
Leif
Message 13 of 15
Guru
IF the 4G modem doesn't have a built in router, then you should connect the Orbi RBR in router mode to the modem.
Leif
Message 14 of 15
LeifA
Apprentice
Yes, it is in router mode.
Some answer here suggested AP mode.
Leif
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 3287 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
