Orbi WiFi 7 RBE973
Reply
Orbi RBR 50 slow download speed, but upload OK
ThKu
Follower
For a year my Orbi RBR50 worked perfectly fine. I have a 500MB download/500MB upload fibra connection, but now I get only 3MB download while the upload continues at full speed. The Orbi is directly connected to the fibre router. I have disconnected it, restarted it, but to no avail. What can I do?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi RBR 50 slow download speed, but upload OK
How are you speed testing? Wired or wireless. Wired is preferred thru the RBR.
Armor, Circle, Traffic Meter.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 525 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
