Reply
Orbi RBR 50
buckleyisaac
Follower
Orbi RBR 50
I currently have an ORBI rbr50 with a satellite.  I am upgrading my internet to cox gigblast and I see that I need a new modem. I was going to buy the Nighthawk CM1200, but I'm not sure if that is compatible with the ORBI rbr50 router? Do I need to buy a different type of router?
Message 1 of 3
UnCapitano
Apprentice
Re: Orbi RBR 50
You should be good with that one, that I know of. I use a CM1000 with mine.
Message 2 of 3
Guru
Re: Orbi RBR 50
ALL CM model modes are compatible with Orbi systems.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 193 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
