Orbi WiFi 7 RBE973
Reply
Orbi RBR 50v2 wont connect to new CM1200 modem
Sleepdoc502
I upgraded my cable modem from CM600 to CM1200, registered it with the cable company and it is connected to the internet and works fine. I connected the ORBI router to the modem but it cannot connect to the internet.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 6
Guru
Re: Orbi RBR 50v2 wont connect to new CM1200 modem
Be sure to connect the WAN port of the RBR to port #1 of the CM1200. Disable LAG on the CM1200 prior to connecting the RBR.
Power OFF both CM and RBR for 30 seconds, then power ON the CM modem first and let it sync, then power ON the RBR. You might want to walk thru the setup wizard by doing a factory reset on the RBR and use a wired PC and web browser to walk thru the wizard. This will help you get the RBR connected and setup with the CM modem.
Message 2 of 6
Guru
Do you have anything else plugged into the CM1200? it does have extra ethernet ports but they can't be used unless your isp allows multiple public ip addresses (most don't) or unless you have port aggregation (orbi doesn't).
Did you try it in this order?
power off both devices.
plug in cm1200. give it several minutes.
hook up the orbi.
power on the orbi, give it a few minutes.
Then try it.
So again, key is don't have anything other than orbi plugged into the cm1200.
Message 3 of 6
Sleepdoc502
Thanks for your help.  I unplugged the other devices from the CM1200 and reset the ORBI.  It was able to connect to the internet, however i am still working ot connect the sattelites.
Message 4 of 6
Guru
sorry didn't know you were having issues connecting the satellites. I'm glad to hear you resolved your issues with getting the orbi online though.
1. What firmware is on the router? And on the satellites?
2. Here's the install article for satellites with description of problems based off the led's.
https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
Tell me exactly where its failing, what the leds are doing, and what you've tried. this helps with troubleshooting.
Message 5 of 6
Guru
The LAN ports on the back of the CM are not for additonal devices. You can connect up a LAG supporting router to Ports 1 and 2 if you enable Link Aggregation on the CM1200. Ports 3 and 4 are for static assigned IP WAN addresses from an ISP. In most cases these will never be used.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1766 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
