Reply
Orbi RBR/RBS50 2.1.4.10 Loses Ethernet Wired Satellite
ElCapo
Luminary
Hi all
I have an RBK53 setup running in AP mode that was working reasonably well on version 2.1.3.4 with wired Backhaul to both satellites.
in fact, recently it had been working so well, with no drops at all for a long prime I thought I would login and see how it looked.
i noticed straight away that I had ‘lost’ both satellites and they were showing as normal connected devices.  I logged into them individually and noticed that they still had connected devices so were apparently operating as additional access points.
i then realised that the router had auto upgraded to 2.1.4.10 but the satellites were still at 2.1.3.4.
So, big question, is everything actually still working as it should?  Does the satellite need to show as a satellite to work properly?  Should I manual update the satellites to 2.1.4.10 or do I run the risk of messing it all up?
i like that I am getting good performance but I also like things to work as designed.
cheers
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 2
Guru
Re: Orbi RBR/RBS50 2.1.4.10 Loses Ethernet Wired Satellite
if it's working then I would let it run. The satellite may of lost temporary connection during the udpate. You may try to power OFF the satellites, then the router for 1 minute, then power back on the router and let it come to ready then power on 1 satellite at a time and let it come to ready, wait for the top LED to turn BLUE before turning on the next one.
What others have found:
https://community.netgear.com/t5/Orbi/I-found-a-Connection-issue-Resolution-for-wired-backhaul/m-p/1...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router R7960P (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 445 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
