- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR/RBS50 Firmware 2.3.0.32 upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
The system as a whole works fine despite different firmware versions for RBR50 and RBS50. Any idea anyone pls how to fix the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR/RBS50 Firmware 2.3.0.32 upgrade
@Krisco1234 wrote:
I just successfully manually upgraded my Orbi satellite RBS50 to the newest firmware version 2.3.0.32 (from 2.2.1.210) . Unfortunately when I tried to do the same with my router I got the message:"The firmware file is incorrect. Please get the firmware file again and make sure it is correct firmware for this product".
Did you first upgrade the RBR50 to 2.2.1.212 before attempting 2.3.0.32? That step is required. There was a size limit in every Orbi firmware prior to 2.3.0.32 that is no longer adequate, so Netgear released a temporary version (212) just to remove the size limit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can post your experiences here as well. Information regarding FW updates for v32 here as well.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a similiar issue but I admittedly updated the RBR50 before the satellites not knowing you need to update satellites before the primary router. Now I get the incompatible file error when trying to upgrade the RBS50 satellite and additional RBW30 Satellite. Any suggestions??? I do not see anywhere I can roll back the RBR50 to the 2.2.0.210 firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the RBS needs to be updated first before the RBR. You can download the v210 FW file and attempt to install it on the RBR. If you can get that loaded on the RBR, update the RBSs directly to v32. Then re-apply v212 and Then v32 ON the RBR.
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-Satellite
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584/highlight/true#M26234
I not sure if you can get back to v210 though...let us know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Darn. I think v212 prevents this.
Can you access the satellites web page at all? I thought someone said they default to 192.168.1.254 or 250 if you put a static IP address on your PCs network adatper @ 192.168.1.50.
You should contact NG support and ask for help in getting the RBS udpated.
@Zooman60 wrote:
It does not allow for a roll back of firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will do. Thanks for the assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
