Reply
Orbi RBR/RBS50 Firmware Updates
pjg61
I was looking at the firmware updates for the Orbi RBR50 based systems. My system currently has firmware 2.1.2.18   BUT  the website shows the CURRENT firmware as 2.0.1.4.
So what is the latest version ?  Normally, the higher the number the new the firmware.
Also, the firmware Release Notes do not show release dates..
Comments ?
TIA
Message 1 of 6
Accepted Solutions
webminster
Luminary
Re: Orbi RBR/RBS50 Firmware Updates
But keep in mind that 2.1.2.18 was recalled, and 2.0.1.4 is the latest recommended firmware.
https://community.netgear.com/t5/Orbi/OrbiOS-MR-2-1-issues/m-p/1506307#M23649
Message 3 of 6
All Replies
Guru
Yes you have the most current up to date FW.
2.1.2.18 is of course the higher value number.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 6
webminster
Luminary
Message 3 of 6
Guru
Well if you have v.18 installed and it's working for you, then I would leave it. If your experiencing problems, then you can downgrade.
Message 4 of 6
pjg61
Thank you for the link. I wish they had posted this on the main Firmware Downloads page.
Since mine appears to be working well, I won't downgrade the firmware.
Message 5 of 6
Guru
Enjoy for now. Downgrade if you absolutly need to.
I presume there working on bugs as we speak.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1852 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
