Orbi WiFi 7 RBE973
Reply
Orbi RBR/RBS50 Firmware Updates
Voodoo_ca
I have the WiFi system with a router and satellite.
Everything has been working fine until yesterday.
I saw there was an update to the v16 firmware so I let it update.
I have a couple issues now.
The strangest is the connection via WiFi from the orbi to my MacBook. It shows connected to WiFi, and it tries to load some pages - but it is SLOW. So bad sometimes that it disconnects. It was fine before the firmware upgrade and a hardware into the orbi to the computer works great. Also, there is an issue where the firmware on the satellite has a NA after it and keeps showing that there is an update.
Is the previous firmware v10?
Can I just do a manual install and downgrade?
Anyone else have these issues?
Chad
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 5
Guru
Re: Orbi RBR/RBS50 Firmware Updates
Try a full factory reset on the router and satellite. Setup the router from scratch. Don't add the satellite just yet. Test the routers wifi. If it seems good, then re-add the satellite.
Message 2 of 5
radamchak
Guide
.16 update instructions say to install firmware manually not automatically. Try it again and reboot.
Message 3 of 5
Guru
Let us know if the suggestions have helped you.
Chad
Message 4 of 5
radamchak
Guide
.16 is supposed to be installed manually.. not automatically.. then do a factory reset after install. Yeah, i know, but hat's what they said.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1782 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
