HighDesert
May 16, 2019Tutor
Orbi RBR/RBS50 Firmware Updates
Got the email from Netgear advising of new firmmware update available, 2.3.1.60. Currently running FW 2.3.1.44. On my iPhone, I go to the Orbi app and do the "check for updates", get the "wait 5 minutes" message for checking and then get the message "problem checking for firmware update". This has been going on for several days now. Normally, updates are not an issue with the Orbi, but I am now at a point where I am not sure what else to try. Any ideas??
Do the update if you want to from a PC with a web browser connected to the RBRs web page. NG is not forcing auto updates anymore so if you see notifications on the web page, email or on the app, its just to let you know there is one available. It's now up to you if you want to upgrade or not.
Thanks for your help, took the time today to go online and did the firmwaare update. All went well using that process. No idea why Netgear dropped the simpler, auto update ability.
Too many other users were complaining about autoupdate breaking there systems so NG relented and stopped that. The system checks for updates, It's not left to the user to update there systems.
Enjoy. :smileywink:
