- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR/RBS50 keeps shutting down
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've these for a while now and they've always worked fine all of a sudden in the last week the router has just shutdown several times and I have to unplug and plug it back in to get anything. Afterwards it works again but of course this has suddenly become unreliable.
Is there any diagnostics or something I can look at? It seems the log is only from boot time so nothing available to see what might have happened.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR/RBS50 keeps shutting down
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
