Reply
Highlighted
Orbi RBR Satellite Question
If I wanted to add another satellite to my Orbi system, do I need to stick with the same model number or can other orbi satellite synch up?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Highlighted
Guru
Re: Orbi RBR Satellite Question
20, 30 and 40 series RBS  or RBWs can connect to your Orbi system
1 series are not compatible with other Orbi systems.
My Setup (Cable 900Mbps/50Mbps)>CAX80>XR450 v2.3.2.106(Router Mode)>RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 92 views
  • 1 kudo
  • 2 in conversation
Announcements
