Reply
Orbi RBR20 5EH3855N022C
KB9JMH
Follower
I have the RBR20 and one (included in box) satellite receiver. The systems works pretty well but I'm wondering if I can improve my signal strrength by adding one more satellite. The folks at a local store have givenm two DIFFERENT answers! (What a surprise!!)
One tech said no, this system is fixed the way it came in the box. The other of course said sure you can!
So, which is correct??
If I can add a satellite, which do you suggest??
Thahks so much
KB9JMH
Message 1 of 3
Guru
Re: Orbi RBR20 5EH3855N022C
Yes you can add more satellites. Other users have posted having up to 6 RBS connected to 1 RBR.
Thahks so much
KB9JMH
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 3
The RBR20 comes as a bundle with the Orbi Satellite (RBS20).
The most appropriate satellite to add is probably another RBS20. This delivers AC2200 wifi, like the RBR20.
The Orbi Wall Plug Satellite (RBW30) is also AC2200, as is the RBS40.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 276 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
