- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR20 Dropping Wi-Fi Network Coverage
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m running an RBR20, and 2 RBS20 satellites. All 3 with the latest firmware. I’ve replaced the modem, I’ve got a replacement Orbi system (hoping my previous was a hardware issue), and I’ve spent several cumulative hours on the phone with NETGEAR Support who were absolutely no help... so the community is my last hope before I just give up on the Orbi.
My problem is simple, sporadically (I just went 2 days without it happening at all) the Wi-Fi network will completely disappear, disconnecting both satellites and all devices from the router. The router doesn’t change colors or do anything, but the Wi-Fi network completely disappears for random times. Sometimes 10-30seconds before reappearing and reconnecting everything. Let me be clear, it’s not an issue with internet connectivity. The modem is getting internet, and the router isn’t changing color (like it would if I unplugged the Ethernet). Some days it will do this 15-20 times and then stabilize and work great for several hours, before throwing a fit again.
Please help...
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20 Dropping Wi-Fi Network Coverage
Is the Orbi system operating in Router or AP mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem: Netgear Nighthawk CM1200
Orbi is in Router mode
2400sq ft with the satellite and router roughly 25ft apart
And I’ve already set the frequency channels and other advanced settings below.
Let me reiterate that it’s not a connection quality issue with my devices or satellites. When they are connected, they work great. The issue is that the entire network (even trying to detect it) disappears sporadically, dropping all devices when it does.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for playing since we don't know what you have tried or what your configuration is, I ask these questions. Helps us to know what you have configured. Not everyone as the same configuration.
"2400sq ft with the satellite and router roughly 25ft apart" a bit too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
If your turn OFF the RBS, is wifi stable?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had the same exact issue with both of the RBS powered off and not connected to the RBR.
I’ve also done a factory reset, booted up only the RBR and sat in the same room while this has happened. Essentially, the Wi-Fi network just toggles randomly between being available and not being available, kicking me and every device off the network whenever it toggles.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset on the RBR and setup from scratch. If this doesn't change anything on the RBR, I would contact NG support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’ve contacted NG Support on 3 separate occasions but when I try to speak with them, no one seems to understand my problem, so I figured I’d try the community forums. Thanks for trying to help 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe environment cause possibly.
Any devices you have that have there own wifi broadcast by chance?
What devices do you have all connected to the Orbi system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can only pick up 4 other Wi-Fi network signals at my house. So a couple of neighbors. They are not very close to me. I do not have anything else generating a Wi-Fi signal in the house.
I’ve got the 2 RBS, 2 laptops, 2 phones, a desktop, and a doorbell camera on the Wi-Fi, however, this behavior happened long before I had several of those devices on the network. I can’t seem to find a rhyme or reason as to why it started happening/happens randomly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where in the home do you have the RBR and RBS placed?
Is this a one level home or multi story? Any basements?
Do you have your prior router by chance? Did this happen with that router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Chydroski wrote:
Understanding I’ve seen this “copy-paste” questionnaire all over the forums, I’ll play along.
The sad part is that it's all from the same person
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you mean my router previous to me getting the Orbi system? Yes I do, and no, this issue did not happen with that router. The issue was that the single router was not good enough to cover the entire top floor, which is why I wanted to get the Orbi mesh system in the first place.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Last system was 20 series Orbi? Not sure if a 50 series system would have different behavior or not.
Seems like the 20 series isn't working well in your home. Most materials of mostly wood and sheet rock or something else?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might try a 50 series system to see if this has any changes in behavior then.
- Mark as New
- Bookmark
- Subscribe
- Permalink
