Orbi WiFi 7 RBE973
Reply
Orbi RBR20 Hard Wire Disconnect Issue
colorbynumber
Follower
Hello,
Seems like I have predictable disconnect issues on my hard wired connection.  No issues on the wifi side.
I have an RBR20 + 2x RBW30 in my house.  RBR20 is connected to a Netgear 16 port gigabit switch.  Which is then connected to a Mac Mini and WD My Cloud NAS.  I am running Plen on the Mac Mini.  Plex has had processing issues and I've narrowed it down to the NAS being disconnected every 20 minutes.  I checked the IP addreess (I thought it was somehow changing every 20 minutes due to the mesh architecture) and the wired connection to the Mac Mini gets dropped -- this does not seem to be the case.
Is there a known issue that NAS connections gets dropped every 20 minutes or some predictable interval?
Thanks!
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 1 of 2
Guru
Re: Orbi RBR20 Hard Wire Disconnect Issue
What FW is currently loaded?
What is the model# of the ethernet switch if one is in the configuration.
Set up Reserved IP addresses for the NAS on the router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 699 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
