- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR20 - Satellite's devices disconnect - no color on Satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have a Netgear Orbi RBR20 with 2 Satellites (RBS20) all router and both satellites are on the same firmware (latest as of today).
I have an issue where one of the satellites's devices lose internet connections but there is no light on top of the satellite. It happens when devices are pulling a lot of bandwidth from the router directly.
Has anyone else experienced this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20 - Satellite's devices disconnect - no color on Satellites
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
