- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR20 Wifi Freezes repeatedly
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello.
I am using an ORBI RBR20 router. Specifications are provided below.
My issue:
My interent connectivity freezes up 4-5 times a day. The ISP provided fiber optic modem has connectivity during these freeze occasions and a wired connection directly from the fiber optic modem works fine during the disruptions. During the outage I dont experience any issues with the Wifi signal/strength either and it is not a device specific issue as the interent connectivity goes out on all devices at home. A restart of the ORBI has been resolving the freeze but its hugely inconvenient. I had earlier experienced issues with DoS attacks but that has been resolved (I dont see any traces of DoS attacks in the router logs). And this particular problem was there even before the DoS attacks started and is there after those have stopped.
Product specification:
- Hardware Version RBR20
- Firmware Version V2.3.5.36
- GUI Language Version V1.0.0.360
- Operation Mode Router
- DHCP Server On
- Region Asia
- 2.4G Channel 11
- 2.4G Mode Up to 400 Mbps
- 5G Channel 36(P)+40+44+48
- 5G Mode Up to 866.7 Mbps
- 5G-2 Channel 157
- 5G-2 Mode Up to 866.7 Mbps
Can someone please help me with the issue? Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20 Wifi Freezes repeatedly
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
