magn3to
May 05, 2022Follower
Orbi RBR20 and Starlink
Hi there,
I am looking at signing up for Starlink however V2 of their router does not have a ethernet port and their ethernet adapter that is purchased seperately is currently out of stock. Therefore I can not plug the Starlink router into my Orbi RBR20.
Is it possible to get the RBR20 to connect to the Starlink router wirelessly?
Thanks!
1 Reply
No the orbi doesn't have repeater or wwan connection
You might be stuck using the starlink router until the ethernet adapter is in stock
