Orbi WiFi 7 RBE973
Reply
Orbi RBR20 keeps dropping internet
Retired_Member
Not applicable
I have had my Orbi RBR20 for a year and a half now and have had no issues.  Beginning this week, it keeps dropping the internet.  I have done multiple restarts and a couple return to factory settings.  When I do these, it works for a few hours then drops again. The main Orbi unit is up-to-date on it's firmware (v2.7.3.22), but the satellite is on a different version of firmware.  Could this cause the issue?  It wouldn't update automatically.  I have an AT&T U-verse Gateway and have called AT&T to see if there were any issues with it, but it appears to be in working order. The internet from the gateway is not dropping. I have googled how to handle this, and have tried all the suggestions, but it's not correcting the problem.  I also find it interesting that my Armor Security protection that comes with the Orbi expired this week. Don't know if that's causing the issue. Can anyone offer any suggestions?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Guru
Re: Orbi RBR20 keeps dropping internet
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 4
Retired_Member
Not applicable
Yes, I have done a factory reset and setup from scratch a couple of times. It works for a few hours. My satellite is not on the same firmware version as the main hub, is that an issue?  I will give your options a try and get back with you.
Message 3 of 4
Guru
RBR and RBS should be same version of FW.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 673 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
