Orbi WiFi 7 RBE973
Reply
Orbi RBR20 regular disconnects
rblades
Initiate
Hello, I have the above Obri Router.  For the past 11 months, it has worked great.  Our internet service provider installed a new modem and since then every day I need to reset the Orbi (unplug, wait 30 seconds, plug back in).  Then it works find for about 24 hours.
Firmware version is: V2.5.1.16
Our cable modem is an Arris model:TG3452.
Any troubleshooting ideas are welcome. Thank you!
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 5
Accepted Solutions
Guru
Re: Orbi RBR20 regular disconnects
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the
Message 2 of 5
All Replies
Guru
Couple of options,
Message 2 of 5
rblades
Initiate
Thank you! I had to call my ISP to turn off the wifi on my modem. Then after resetting the whole system we have been stable for a week. Thanks for the help!
Message 3 of 5
Guru
Enjoy, Smiley Wink
Message 4 of 5
Teelak
Hey Furrye38, I sent you a private message, if you don't mind looking at it, I have a similar situation with my C7800 disconnecting often.
Model: C7800|Nighthawk X4S-AC3200 WiFi Cable Modem Router
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1239 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
