- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR20 slow upload speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a 300 mbps internet service plan with Xfinity and am having issues maintaining proper upload speeds when I run speed tests. My download speeds are typically between 250-350 mbps, and upload speeds between 10-12 mbps. Currently, my download speeds are relatively normal, however, my upload speeds are between 0.5-2 mbps.
I've had this issue in the past and it ended up being because there was a firmware update for my router. I have downloaded and installed the most recent firmware for the RBR20 router (v2.6.1.36) along with my RBW30 satellite (v2.6.1.6). I've continued to run speed tests after the fact and still cannot obtain an upload speed greater than 2 mbps.
This is causing my internet connection to be very slow, especially with my kids gaming systems. Does anyone have any recommendations on how I can bring my upload speeds back to the 10-12 mbps range?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20 slow upload speed
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Is Armor or Circle enabled on the RBR>?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@JulietFalcon wrote:I have a 300 mbps internet service plan with Xfinity and am having issues maintaining proper upload speeds when I run speed tests. My download speeds are typically between 250-350 mbps, and upload speeds between 10-12 mbps. Currently, my download speeds are relatively normal, however, my upload speeds are between 0.5-2 mbps.
Your Orbi upload speeds should certainly be higher and close to your 10-12 mbps. Try the community faq to first narrow down whether the upload speed loss is from the Orbi, wireless and/or wired, etc.: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The modem manufacturer and model is Arris Surfboard SB6183. I am unsure how to check if armor is circle is enabled.
Once the update to firmware v2.6.1.36 was complete, resetting the modem and router seemed to fix our problems for the past couple weeks, but here we are again. Download speeds are fine, but upload speeds are back to 0.5 - 2mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have Armor enabled, it wil be on your mobile Orbi app and also appear on the RBRs web page as enabled on the first page if you look at the RBRs web page with a web browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We do not have Armor activated on our device.
We have an Xfinity field technician coming tomorrow. I've spoken with Arris customer support and they've informed our downstream bonded channels are fine, but that our upstream bonded channels should be between 45-51 and our currently at 42. Arris also had me connect directly from the modem to my laptop, and the speed tests came back with the correct speeds which lead me to believe that there is an issue with the router, however, the Arris tech contined to say it is more likely the result of the upstream bonded channels power levels too low.
Any insight on this? We had a field technician come out about 6 months ago and informed of the upstream bonded channels being too low and they had no idea what I was talking about.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was your slowdown before or after your fw update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
@JulietFalcon wrote:We do not have Armor activated on our device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This has been an ongoing issue for several months. In the past, the firmware updates will typically solve the issue for 2-3 days and then the upload speeds drop back to 0.5-1 mbps.
Xfinity informed me today that our plan is actually a 400mbps plan, not the 300 we agreed to which I found extremely odd, and that our current modem only provides speed up to 373mbps. I've ordered an Arris surfboard SB6190 which allows up to 600mbps which will be here tomorrow but at this point I'm unsure what is going to resolve the issue.
After we scheduled the field technician, another technical support member from Xfinity called to see if they could fix the issue without having to send a field tech out and had me connect directly from the modem to my laptop and once again my download speeds were in the 200-250 range and upload back between 0.5 - 1 mbps. They decided we should wait an hour and will be calling me back in a few minutes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possibly line issues on your network
how old is your modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was purchased from Best Buy in March of this year, so 9 months.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would avoid the SB6190:
@JulietFalcon wrote:This has been an ongoing issue for several months. In the past, the firmware updates will typically solve the issue for 2-3 days and then the upload speeds drop back to 0.5-1 mbps.
