Orbi WiFi 7 RBE973
Reply
Orbi RBR20 - upgrading Firmware from 2.3.5.26 to 2.3.5.36
Ruskiwi
Greetings.  Received an email from Netgear recently that a new firmware version was available and to upgrade (V2.3.5.36). Logged in to Netgear Support and found 2.3.5.36 to download which I have done.  Yet I can see no confimation of this in either the web browser or phone app management interfaces where it still refers to 2.3.5.26 as the current firmware version.  Anyone got any experience with this?  Thanks, Regards, Russell.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Accepted Solutions
Guru
Re: Orbi RBR20 - upgrading Firmware from 2.3.5.26 to 2.3.5.36
You can manually update to v36 by downloading the RBS and RBR FW files from NG download site. Using a wired PC and Web browser, send the RBS FW file first, then update the RBR lastly.
Also if the system is working well, you don't have to update FW.
The Orbi App or Web page may not reflect new FW as it may not be posted to the Update servers as of yet.
Message 2 of 4
All Replies
Guru
Message 2 of 4
Ruskiwi
Many thanks for the prompt response and your knowledge. All things considered, your Option B seems the one I'll go for: "if it ain't broken, don't try to fix it" !  I'll wait until a mandatory FW upgrade notificatiion appears.  Thanks again.
Message 3 of 4
Guru
Enjoy.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4401 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
