- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR20 won’t hold connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’ve rebooted the ISP modem and Orbi numerous times and it doesn’t fix it. Please help??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20 won’t hold connection
What the modem and RBR disconnected and reconnected during the office change?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Lucent-Alcatel. Modem unknown. It provides Cox Gigablast internet
What the modem and RBR disconnected and reconnected during the office change?yes everything was disconnected and reconnected
Has a factory reset and setup from scratch been performed since last FW update? Yes attempted twice last night but no change and appears to not have taken the reset.
FYI I’m going to attempt a firmware rollback in a few minutes
- Mark as New
- Bookmark
- Subscribe
- Permalink
Id power OFF the modem again while doing the FW update and then power OFF the RBR as well. Then power ON the modem then RBR.
Enusre the lan cable is good between the modem and RBR. CAT6 is recommended. Make sure the plugs are seated well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the impact of having satellites on later FW than the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unless you notice something bad happening, you can run more recent version of FW on RBS while RBR is running older.
