- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR20
- Mark as New
- Bookmark
- Subscribe
- Permalink
I switched internet providers and purchased a Nighthawk X6S AC4000 wifi router. I also previously had the Orbi RBR20. The orbi is not connecting or meshing with my new nighthawk. Can anyone tell me why? I have tried uninstalling the app and doing a fresh reconnect.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20
X6s isn't a model. neither is ac4000, its a speed. which model is it?
Are you going modem-----AC4000------orbi?
If so, do you have the orbi in AP (access point) mode?
Otherwise you're running 2 routers in router mode on your network and you end up with a double nat which can cause your issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20
Perhaps this is it: https://www.amazon.com/NETGEAR-Nighthawk-Tri-band-Ethernet-Compatible/dp/B072LZZZXB
Certainly a combination router/WiFi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20
Any progress on this?
@skymetal wrote:I switched internet providers and purchased a Nighthawk X6S AC4000 wifi router. I also previously had the Orbi RBR20. The orbi is not connecting or meshing with my new nighthawk. Can anyone tell me why? I have tried uninstalling the app and doing a fresh reconnect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR20
Ok. Glad you got it working. Please mark your thread as solved so others will know.
Enjoy.
