× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 3 replies
  • 1081 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Orbi RBR40 Satellite devices
Can I add netgear satellite devices other than the RBS20 to extend the mesh system tied to my Orbi RBR40?  I currently have 2 RBS20’s along with the RBR40, but was interested in adding one or two more satellite devices to further extend the coverage and wasn’t sure if I had options other than the Orbi RBS units or Orbi RBW units.
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 4
Highlighted
Guru
Re: Orbi RBR40 Satellite devices
the orbi satellites are compatible with all the systems. the only difference is the RBR50 system has a wider backhaul but since you have the RBR40, it'll be fine.
CM1100->RAX200->GS716v2->RBR50->RBS50-RBS40V-RBS50Y
Message 2 of 4
Highlighted
Thanks for your response.  Is it also possible to use other Netgear equipment (not necessarily Orbi), such as the NETGEAR Nighthawk® AC2200 X4 WiFi Mesh Extender (EX7300-100NAS)?
Message 3 of 4
Highlighted
Guru
Others have reporting using EX8000 series with orbi. There was a problem found by one user that his EX8 series would no longer connect to Orbi. NG have him a beta. I found this issue as well with my EX7700 series. A beta FW file fix the EX7700. I don't know if older model EX will exhibit the same issue or will be compatible. So far EX7 and 8 series are.
My Setup (Cable 900Mbps/50Mbps)>CM1100>Orbi RBK50 v2.5.1.16 and Orbi RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK852, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 4 of 4
