Orbi WiFi 7 RBE973
Reply
Orbi RBR40 VLAN Wired
billStevens243
Follower
I'm trying to set one of the wired ports so that it is a separate VLAN for IOT (Smartthings hub).  How do i know which physical port is associated with Port 1 on the GUI?
Message 1 of 2
CrimpOn
Guru
Re: Orbi RBR40 VLAN Wired
Using the web interface, bring up the Advanced Tab->Advanced Home, and click on Show Statistics.  This brings up a page showing the speed of each LAN port.  If (anything) is connected to only one of the ports and (nothing) to the other ports, only one port will show a connection.Ports.JPG
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 512 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
