Orbi WiFi 7 RBE973
Reply
Orbi RBR40 - cannot login and security questions fail. What do I do?
micahchase
Follower
I have an Orbi RBR40 but dont remember the admin password.  I was able to login to the password recovery but the answers to the security questions appear not to be correct. How can I get into my router for updates?
Message 1 of 2
ekhalil
Master
Re: Orbi RBR40 - cannot login and security questions fail. What do I do?
I think that your only way out of this is to do a factory reset.
  1. Make sure your Orbi device is powered on.
  2. Using a paper clip or similar object, press and hold the Reset button until the Power LED on your Orbi device blinks amber.
    https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2123 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
