Orbi WiFi 7 RBE973
Reply
Orbi RBR40 dropping WiFi 4 times a day?
jonathanch
Is there a way to track my WiFi conectivity to see if my Orbi is dropping the WiFi.
I am using Verizon Date 4 times a day when we are at home and supposadley connected to WiFi.
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 11
Guru
Re: Orbi RBR40 dropping WiFi 4 times a day?
I'm not sure what you mean you're using verizon date.
Firmware on the orbi?
Is it only wireless device dropping or wired devices as well?
What modem are you using?
Message 2 of 11
jonathanch
Thanks for the reply. That should have been data not date.
On my Orbi App it showes my Hardware as RBR40 with firmware V2.3.5.30.
I am trying to track down why my phones use data every 6 hours even when we are home and supposedley connected to the Orbi. (See attached data log from verizon)
My ISP is Cincinnati Bell Fioptics with a ZYXEL modem.
I never have to reboot the Orbi
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 3 of 11
jonathanch
Only wireless is dropping as far as I can tell.
Message 4 of 11
Guru
Can you tell that devices are disconnecting from the orbi?
Is it all devices having this issue or only one?
Or you've just noticed that periodically when you should be on wifi, you're phone is using data?
What zyxel modem is it?
Message 5 of 11
badbrain
I'd recommend manually updating your firmware. The automated check doesn't seem to identify that there's new firmware available.
Message 6 of 11
jonathanch
I am only conserned with my phones using data.
EMG341S-B10A
Message 7 of 11
Guru
You modem may already have built in router and wifi, if so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
EMG341S-B10A
Message 8 of 11
jonathanch
I have turned off the WiFi on my Zyxel modem/router and my phones are still using Data 4 times a day at 12 & 6 AM and PM.
I tried to log on to my orbi (orbilogin) but I can't. Don't know why.
Message 9 of 11
Guru
maybe its your phones?
Easy way to check? Turn the wifi back on while on the zyxel and connect the phones to its wifi. If they still use data, its something to what they're (the phones) are doing.
Message 10 of 11
mynameisjohnj
I've started disabling mobile data on my phone when I'm in the house.
A quick google search will show that the Orbi wireless reliability is extremely poor... when I have my cellular data turned off I lose internet for a few seconds every so often - I doube I've had a stable connection for more than a half hour.
This only started recently... so I'd personally be hesitant about upgrading the firmware. I'm on the latest (2.3.5.34) and the connect is abysmal.
- John
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1413 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
