- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR40 issues updating Samsung devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a very strange issue that has recently started. Not sure when it started but I cannot seem to correct this issue. The issue is, I cannot get some of my Samsung devices to connect to the firmare update server to check for device updates (Samsung update server). I have 4 Samsung devices, 2 Note 8's, 1 Samsung tablet and 1 Note 9. The 2 note 8's and the tablet will not connect but the Note 9 will... I have been all through the settings on the Orbi and nothing seems to work. I have factory reset the Orbi with no luck. My network modem is just a modem (no router at all). Not sure where to go from here. Any idea's?
I have also tried to go back a few firmware version but the issue still is present.
Hardware Version | RBR40 |
Firmware Version | V2.3.1.58 |
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just to update this post. I installed an older router/ap in place of the Orbi and I was experiencing the same issues. I contacted my provider and swapped out the modem. Changing the modem (only a modem) has corrected this issue.
Thanks for all of the feedback.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR40 issues updating Samsung devices
Is the Orbi system operating in Router or AP mode?
Try setting 1.1.1.1 and 9.9.9.9 DNS addresses on the RBR...
- Mark as New
- Bookmark
- Subscribe
- Permalink
FURRYe38,the modem is
ARRIS DOCSIS 3.0 / PacketCable 2.0 Touchstone Telephony Modem
Since this is a modem only, I am running the Orbi in Router mode.
As for the DNS, I have already tried that. I have also tried adding the Samsung device to the DMZ. |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this the only devices that are having problems? Do other devices have full internet access?
Do you have any parental controls enabled like Circle or Armor? Disable them if you do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far this is all that I can see that's not working. I have a seperate circle device that I have disconnected (same issue with or without it connected) I have the Circle feature off in the Orbi.
If I tether the Samsung tablet to my phone (on 4G) it connects to the software update server and if I take these devices to another network they connect. Next step is to replace the Orbi with my old AP and see what happens (it will connect so I don't even know why I'm wasiting the time).
I've also packet captured the deivce that does not work and the one that does work when performing the update and they both seem to send broadcast's to 224.0.0.251
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would factory reset the Orbi. While do you that, power OFF the ISP modem for 30 seconds then back on. Walk thru the setup wizard with a wired PC and web browser. Set up the RBR only. Do not load any saved backup config files. Just start a new. Try setting same SSID or something different. Then test your Samsung devices to see if they connect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As stated in the original post....I have already factory reset the Orbi. I have not tried a new SSID though. Not sure why this would correct this problem since 1 of the 4 connects to the update server but it's worth a try... FYI.. the devices did connect when I installed the Orbi back in Jan.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tired another reset with no config restore and a new SSID. Same issue as before. Not sure where to go from here.. Is there any way to get a ticket open with Netgear if I don't have support?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can confirm this issue also exists on the RBR50. Neither my Samsung Galaxy Note 9 or Galaxy Tab S4 can connect to Samsung update servers when connected to the Orbi hotspot at home. It works on any other wifi hotspot (including my old wifi router). I have replaced the Orbi with a new one at my local Best Buy store, performed several factory resets, tried using Orbi without the Sattelite turned on to no avail. Additionally I am also having performance issues when the Orbi is put in AP Mode (I have a support case open for that issue already). I wonder if these problems are related in the Orbi software somehow. Its been a frustrating experience with this Mesh wifi system and am regretting not going with either a Cisco or Ubiquiti access point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
@chathamws wrote:I can confirm this issue also exists on the RBR50. Neither my Samsung Galaxy Note 9 or Galaxy Tab S4 can connect to Samsung update servers when connected to the Orbi hotspot at home. It works on any other wifi hotspot (including my old wifi router). I have replaced the Orbi with a new one at my local Best Buy store, performed several factory resets, tried using Orbi without the Sattelite turned on to no avail. Additionally I am also having performance issues when the Orbi is put in AP Mode (I have a support case open for that issue already). I wonder if these problems are related in the Orbi software somehow. Its been a frustrating experience with this Mesh wifi system and am regretting not going with either a Cisco or Ubiquiti access point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Once i get an answer from them I'll update this post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @chathamws
Our engineers are looking into this issue. We would like to request for debug logs. Please check your inbox.
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can confirm my RBK50 isn't reproducing this. Mines in AP mode behind a XR450 router with a Galaxy Tab S2.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
@SinmanTX wrote:Just to update this post. I installed an older router/ap in place of the Orbi and I was experiencing the same issues. I contacted my provider and swapped out the modem. Changing the modem (only a modem) has corrected this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, I believe the problem is elsewhere after doing more troubleshooting. I think it was coincidental that this problem with samsung update started occuring around the same time I installed the RBK50. I have performed packet captures with my PFSesne firewall/router and it looks like samsung is blocking some of Spectrum's network. I will need to reach out to Spectrum Cable to further troubleshoot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know.
@chathamws wrote:OK, I believe the problem is elsewhere after doing more troubleshooting. I think it was coincidental that this problem with samsung update started occuring around the same time I installed the RBK50. I have performed packet captures with my PFSesne firewall/router and it looks like samsung is blocking some of Spectrum's network. I will need to reach out to Spectrum Cable to further troubleshoot.
