Orbi WiFi 7 RBE973
Reply
Orbi RBR40 router - 2 on 1 network?
mscleare
Follower
I bought an Orbi Kit with the RBR40 router and 2 R BW20 satellites. It worked fine until I moved to a much bigger house with an outside area that needs coverage. I have access to a similar kit (only 1 satellite) from a friend for free. I believe I need at least 2 satellites extension points for full coverage. Can I install the 2nd router on teh same network (same name) and will it act like a satellite and extend the network? Or am I limited to one router and can only use the satellites to extend the coverage? Sorry if this is obvious. I'm not a networking guy.
Message 1 of 2
Guru
Re: Orbi RBR40 router - 2 on 1 network?
No, the RBRs only work in router or AP modes. They do not work as satellites.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 426 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
