Discussion stats
  • 3 replies
  • 422 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Tutor
Orbi RBR40 system working fine - but have one windows 10 pc that will not connect
Have a new (installed yesterday) RBR40 and 2 satellites.  Its working fine - and have two imacs, a pc using windows 8, the chromecast and even the vpn working happily together.
But having trouble connectioning a pc running on windows 10.
Oddly it worked happily for a few hours, but then stopped - and no amount of forgetting networks or installations and reboots and obvious firewall changes have worked.
Orbi sees the pc and lists it as connected and allowed - meanwhile the pc shows the orbi as connected, but says no internet is available through it.
Any ideas?
Message 1 of 4
Highlighted
Virtuoso
Re: Orbi RBR40 system working fine - but have one windows 10 pc that will not connect
Hi @Mogg,
                  Check for any static IP assigned on that PC and remove it.
Message 2 of 4
Highlighted
Tutor
Thanks - seem to have solved it (permanently who knows??!) by removing the vpn app from that pc.  Reinstalled and now seems fine - lets hope it lasts!
Message 3 of 4
Highlighted
Virtuoso
Hi @Mogg,
                  Good to know that your issue is resolved.
Message 4 of 4
