- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR40 wifi speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just upgraded from ATT 300 to ATT 1 gig fiber service to the house but max wifi download speed from Orbi RBR40 is 300Mbps. Can I get more?
Setup:
ATT router (Arris BGW210) > Orbi RBR40 (AC2200, FM V2.5.1.22). There are also 2 RBS20 satellites (FM V2.5.1.22) placed in other parts of house.
Ethernet cable from iMac into Orbi RBR40. Speedtest on iMac using ethernet via RBR40 is 930Mbps.
Approx 12 devices on wifi network (computers, phones, TV)
Question - iPhone 8 placed 2ft from Orbi RBR40 only gets 300Mbps download. Can I get more - possibly via reconfiguring the Orbi? I am not technical so can't remember how to get to Orbi router settings. Or is it time to buy a new wifi system?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR40 wifi speed
What are your wired speeds with a wired PC connected to the RBR?
Most iphones and WiFi 5 devices will max out at around 400-500Mbps due to the antenna design, 2x2. Even my 12 Max gets around 400 to 500ish speeds. You'll not see anything near 900Mpbs on 5Ghz AC wifi. Wired you should.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wired download speed with a wired PC connected to the RBR = 930Mbps
Is there a way to increase the RBR wifi speed from 300Mbps to the 400-500Mbps max? Or is 300Mbps the best I should expect?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can try reviewing these:
Your getting around normal speeds for wifi devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In the iOS app store, look for "Wi-Fi Sweetspots" app. It will check the connection speed between your iPhone and your wifi router (or satellite, whiechevr you happen to be connected to) as you walk around. It is not affected by your ISP connection speed. It gives you the maximum "raw" speed, so to speak.
You can monitor the speed as you walk around the house. Start in the same room as the router (base) and see what speeds you get.
