Reply
Initiate
Orbi RBR50 2.5.0.38 firmare bug
Attached devices list has bogus device name etc. info and can no longer be edited. Althought the edit device name screen appears no changes ever get applied after pushing apply button.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 11
Accepted Solutions
Initiate
Re: Orbi RBR50 2.5.0.38 firmare bug
Version 2.5.0.40 fixes fo the problem for me.
Message 4 of 11
All Replies
Sensei
This has been a complaint since this firmware was released.  The ability to customize device names and types is "totally broken."
Some people have found that the new firmware solves more pressing problems.
Others have found even more deficiencies and have moved back to 2.3.5.30.
I, personally, waited to see what people were finding and have decided to ignore this firmware update.
I love my Orbi.
Message 2 of 11
Guru
Care to give v40 a try? Looks like one user said the naming of devices seems fixed for him.
https://community.netgear.com/t5/Orbi/Where-are-the-device-names-located-when-in-a-telnet-session/td...
My Setup (Cable 1Gbps/50Mbps)>CM1200(LAG Disabled)>RBK853 v3.2.16.22
RBK50 v2.7.2.102
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 3 of 11
Initiate
Message 4 of 11
Guru
Awesome. Glad its working. Please mark your thread and solved so others will know.
Besure to make a backup configuration to file for safe keeping.
Enjoy. Smiley Wink
RBK50 v2.7.2.102
Message 5 of 11
The new firmware (.40) did not fix the problem for me, although I didn't do a factory reset as it takes far too long to set everything back up. Although I still can't change/save device names or icons, .40 does at least correctly display previously saved names, rather than just showing the devices' MAC addresses.
Message 6 of 11
Guru
One poster reported that a reset help with this for his system. If you need device naming abilit, you'll need to downgrade to v30 or v34.
RBK50 v2.7.2.102
Message 7 of 11
Luminary
I got an email informing me that new firmware is currently undergoing "DQA testing" and if it qualifies it should be officially released next week.
I'm not holding my breath that it will fix the recent issues we all have been experiencing.
If it doesn't I'll be on to their CEO and CTO yet again asking them what sort of incompetence is going on within Netgear...
Message 8 of 11
Luminary
*That should be "SQA testing" not "DQA testing".
Message 9 of 11
Since foolishly updating from 2.3.5.x to 2.5.0.40, my RBR has started crashing/becoming unavailable every few days.  How can I downgrade back to 2.3.5.x which worked basically fine?  (slightly less pretty around device icons, but I didn't notice any other changes).
Message 10 of 11
Guru
Did you factory reset the RBR after applying v40? Mine never saw this crashing after I applied v40.
You can downgrade to v34 if you want too. Just manually download the FW files and apply. I recommend factory reset the RBR and setup from scratch after applying v34 to ensure it's installed correctly.
RBK50 v2.7.2.102
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1820 views
  • 1 kudo
  • 6 in conversation
Announcements
