Orbi WiFi 7 RBE973
Reply
Orbi RBR50 Can't Download Firmware
ralphp21
Hi.  My iPhone X Orbi app won't connect to my home network but I'm able to connect to the router via remote management.  However, when I go to Router Settings, there is no "Update Firmware" or "Search For Firmware Update" option, only a reboot option.  How can I get the latest firmware update onto my router?
Thanks in advance for your help.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 6
Guru
Re: Orbi RBR50 Can't Download Firmware
I recommend using a wired PC connected to the router and use IE11 or FF browser and manually download the FW files from NG support site and manually install the files. Update the satellite(s) first then the router.
Message 2 of 6
ralphp21
Will do.  Thanks for the quick response.
Message 3 of 6
Guru
What Fw is currently loaded?
Message 4 of 6
ralphp21
2.1.4.10
Message 5 of 6
Guru
Ok, should be good to manually upgrade to v.16 if thats what your doing.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1030 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
