Reply
Orbi RBR50 Device Names not Saving
RodanThrelos
Tutor
I'm using the RBR50 through my Verizon Router as an AP and I'm trying to change the device names of my connected devices to know which device is which.  Initially, when I was setting up the first few devices, I changed their names through the iOS app, and they changed (although one or two I had to do more than once for it to stick).  Now I'm attempting to finish with the last few devices and nothing I do makes the name changes stick.
I've tried through the app, but as soon as I refresh, the name and icons revert back to what they started with.  I attempted to use the browser client (both with Chrome and Edge), and I had the same problem.  In fact, almost none of my changes through the web client made any difference.  I have tried rebooting the Orbi router, to no avail.  There seems to be no corellation between the devices; they range between iPods to Computers to game consoles, both connected to the Base and to the Satellite.
I'm pulling my hair out!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 116
Guru
Re: Orbi RBR50 Device Names not Saving
I can confirm this as well with v38. Device appear and are correctly icon'd. However after editing about three items the UI seems to stop accepting changes. Using Opera on OSX 10.14.6
@Blanca_O
@Christian_R
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v3.2.18.223/SRK30 V3.2.33.106)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, RBK50, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 116
JVRiley
Initiate
The latest FW update (v2.5.0.38) re-introduced this bug, if that's the firmware you're running.  Sometimes name/icon changes work, other times they don't; sometimes names and icons randomly change between Orbi reboots.  More than annoying for OCD-me.
Message 3 of 116
RodanThrelos
Tutor
Yes, also using Firmware version V2.5.0.38.
Message 4 of 116
Rshotok
This is driving me crazy, as I have the same problem.
Model: A6100|WiFi USB Mini Adapter, RBR50|Orbi AC3000 Tri-band WiFi Router
Message 5 of 116
Guru
Please contact NG and let them know about this:
https://www.netgear.com/mynetgear/registration/login.aspx
Message 6 of 116
Hixz
Guide
Same issue with this fw .38....
Can't save device names and wiped out most of my custom names.
Message 7 of 116
Guru
Message 8 of 116
Guru
NG is checking on this:
https://community.netgear.com/t5/Orbi/Orbi-Firmware-Update-2-5-0-38/m-p/1814846/highlight/true#M7351...
Please be patient.
Message 9 of 116
Blanca_O
NETGEAR Moderator
Hi, All,
Let me check on this. I will get back to you for any updates.
Blanca
Community Team
Message 10 of 116
LSStream
Guide
Same problem
Message 11 of 116
singhravik
Guide
Any comment on the satellites dropping wifi connectivity to base? is wifi stanility better on this 2.5.0.38??
Message 12 of 116
LSStream
Guide
I have not noticed any change in stability, although I have not really had any issues with satellites losing connectivity to the base in either wireless or wired backhaul configurations.
Message 13 of 116
Guru
Please make  new post in regards to your RBS now working well and we'll help you out there as this thread is unrelated to your problem.
Message 14 of 116
schornstadt
Tutor
Same issue here.
Message 15 of 116
Guru
NG is aware of this. You'll have to wait until NG fixes this.
@schornstadt wrote:
Same issue here.
Message 16 of 116
JMU1998
Luminary
Same issue icons incorrect will not accept changes to icons or names.
Message 17 of 116
Guru
Message 18 of 116
Another company where the community has to be their QA team....
Message 19 of 116
Tizmasel
Initiate
Same problem here. I updated today then realised something was wrong. Subsequently found this thread. There's clearly a significant bug in this update so why wasn't it pulled earlier?
Message 20 of 116
Retired_Member
Not applicable
A better question...why did you upgrade?
Message 21 of 116
Retired_Member
Not applicable
Not necessarily....can you spell 'REVERT'
Message 22 of 116
Tizmasel
Initiate
Sorry @Retired_Member, that's not a better question. It's a pointless question.
Message 23 of 116
Retired_Member
Not applicable
Truth hurts
Message 24 of 116
Guru
THe naming of devcies is confirmed and known and NG is aware of it. The impact of naming devices is really not a show stopper and more of an inconveience to users. Doesn't really impact operation or cause the system to fail, thus no reason to pull it.
Users will need to be patient, I presume the next FW update will have a fix.
Message 25 of 116
Top Contributors
Discussion stats
Announcements
