- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 Internet Port Dead?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Randomly tonight, the Orbi went out. When I checked the connection to the Comcast modem, the lights were not active/lit up for the connection from it to the Orbi.
I connected a VPN router and the lights were active. I connected a laptop and the lights were active.
I performed a factory reboot and the lights were still inactive.
Any other suggestions one what I might do to trouble shoot this, or is it possible that my port is dead?
Would appreciate any input and advice!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 Internet Port Dead?
Is it just the WAN port or all ethernet ports?
Here's what i'd start with.
1. You've tried the factory reset. Great.
2. Try a new cable. Maybe something is wonky. 🙂
3. Try reloading the firmware. Manually install the firmware (possibly try 1 version older) and reset it afterward. Make sure to do it over a hardwired connection
4. If it didn't work, maybe something did fry the port. If you're not still within your warranty period, there is the option to mirror the wan port to lan port 1. go to 192.168.1.1/debug.htm (or whatever your orbi's ip address is) and check off the mirror wan port option.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the feedback!
I've tried multiple cables--they were associated with the different devices and I was not clear there. I also cannot connect to the device to get on its wifi, so we're now at the replacement phase, which means there's a resolution, at least.
Thanks again!
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is really annoying that Netgear "saved a dollar" by not putting connection and activity lights on the ethernet jacks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I miss the days of having LED on the ports in back of routers. So nice to know that there is activity or not. Mfrs gotta save money somewhere.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I find it really interesting that I received an email stating that the above (swap cables) was accepted as a solution.
I didn't do that.
I'm not sure why Netgear would have something trigger this, or a moderator, or whatever.
I find this to be unethical when I have already stated that this didn't work and Netgear has replaced the unit.
I'm sharing for visibiltiy for others.
I do not think I'll continue to use these forums, nor do I feel comfortable using Netgear products in the future. This feels mighty suspect, especially for an organization that sells security and privacy as part of its solutions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Me, either. Hence the post.
I've attached a screen shot, software glitches and all, in the event anyone should infer that perhaps I'm being dishonest in any way.
- Mark as New
- Bookmark
- Subscribe
- Permalink
More like user mis-configuration. I get emails all the time from the forum.
Sounds like it's solve anyways. Good luck in your endeavours.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I know he's left the forum. Thanks.
