Orbi WiFi 7 RBE973
Reply
Orbi RBR50 + RBRS50 firmware stuck on V2.1.4.16_1.0.0.11
KFRALICK
Cannot update firmware
Message 1 of 7
Guru
Re: Orbi RBR50 + RBRS50 firmware stuck on V2.1.4.16_1.0.0.11
You should be able to directly manually update to v44 on the RBS First. Try v210 or v212 if v44 does not work at first.
Then you need to manually apply v212 to the RBR next. Then manually apply v44. V212 is needed before v44.
Message 2 of 7
KFRALICK
Its not working either way. when I try to update manually it keeps telling me that the file is incorrect?
Message 3 of 7
Guru
And you did unpack the .zip file to reveal the sub files correct? And you tried to apply v210 and v212 first to the RBR?
If so, I would make contact with NG support:
https://www.netgear.com/mynetgear/registration/login.aspx
Message 4 of 7
aykornb
have same issue... i think it's because it's a verizon branded sattelite
Message 5 of 7
CrimpOn
Guru
Oh, s**t.  You are screwed.  Service providers change the firmware to allow only them to perform updates. There is a thread on the forum about one Verizon customer who went so far as to try to force a firmware update using the Trivial File Transport Protocol (TFTP) which is built into the routers.  As I recall, this BRICKED the Orbi.
If the Orbi is not working in some manner, maybe you can escalate the issue to "Level II" (or whatever) and get a better resolution.
Message 6 of 7
Guru
IF this is a Verizon branded system or unit, then upgrading with NG stock FW will not work. You have to go back to Verizon to see if they have FW that you can update on there branded systems. NG stock FW will not work in this case.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1182 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
