Reply
Orbi RBR50/RBS50 Firmware Version 2.3.1.44 constantly dropping wifi connections to iphones/ipads
Updated my RBR and 2 RBS satellite (also have 2 RBSK outdoor satellites that did not update) a few days ago.  Worked fine until yesterday and now none of our iphones or ipads will stay connected for more than a few moments.  Most of IOT  wifi connected devices in the house are fine as is my desktop.  Anyone else having or have had this problem?
I can renew the lease on the iphone wifi and it will connect for about 30 seconds but then it gets booted off to LTE.  All phones in the house having he same issue.
Solutions?  Thanks
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 7
Guru
Re: Orbi RBR50/RBS50 Firmware Version 2.3.1.44 constantly dropping wifi connections to iphones/ipads
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Set up some IP address RESERVATIONS on the RBR for your devices as well.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 2 of 7
jsturess
Apprentice
Seems like we are some people now that have this problem and no solution in place
Above post dosent help, have tried them.
____________________
RBK53| Orbi Router + 3 Satellites
Arlo Pro 2 (9 cameras)
Message 3 of 7
jsturess
Apprentice
@MrToadsWildRide do you also have problem with gui presenting connected devices? switching between wired/2.4/5? and also which it is connected to, changes from router to one of the satelites and so on?
You have to look for some minutes to see this behavior.
Message 4 of 7
Guru
Any progress on this?
Solutions?  Thanks
Message 5 of 7
jsturess
Apprentice
My wifi also still drops but for all devices, see attachment. Today the "connection type" and connected orbi" seem so work, it dosent chage from wifi to wired and so on under connected devices. What I have changed since last time is "transmitt power controll" to 100% for both 2,4 and 5GHz, seems to stable "connection type" but it still drops wifi.
Message 6 of 7
Guru
Have you updated to v48 and done a factory reset and setup from scratch after the update?
Try enabling or disabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Test system with all cameras turned off.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1250 views
  • 0 kudos
  • 3 in conversation
Announcements
