- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 Router going off-line frequently
- Mark as New
- Bookmark
- Subscribe
- Permalink
Over the last few weeks the ORBI RBR50 Router wirelss access has been going off-line frequently, and almost daily now (or it seems.) It may work great for a day or two then the wireless quits working. All hardwire devices are working fine, the Router in-app (on Android phone) shows RED, while the satellites show green. I updated the firmware to v2.5.1.8 hoping that the issue would resolve, but it unfortunately hasn't. Rebooting tends to resolve the issue for some time, but then it begins to drop again.
I've got 70 plus devices that connect to it (smarthome devices, computers, etc.), and prefer not to have find a more reliable solution (if that even exists) and have to reset all wireless devices to access something new.
Any ideas where to start troubleshooting or resolving this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 Router going off-line frequently
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 Thanks for the direction.
No factory reset has been performed. Before I do that, #1 question is if I reestablish the same SSID and Passwords, will my wireless devices reconnect or will I have to reset each device manually (40+ smart home devices on wireless)?
"Modem" is a ZHONE Mode ZNID-GE2424-NA-0GN-ICA Rev. A1 - on Fiber internet connection, which I have no remote access to manage.
Home is approx. 3600 SQFT, distance is approx. 30' distance, standard frame construction. Router is on main floor, while Satellites are on 2nd and basement floors opposite router east and west. Current setup has been in place for 2 years.
2.4GHz was Auto, 5GHz was channel 48, have set to 6 and 44 respectively.
10 Wifi neighbors at last count/scan. Overlap on 2.4 channel one w/several neighbors (before reassigning to channel 6).
Disabling settings as recommended, set to short preamble and 40mhz only (assuming disable 20/40 defaults to 40), and testing/monitoring wireless connectivity.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After a factory reset, once you set your WiFi SSID and password to the same values as before, all of your previously configured WiFi devices will reconnect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Make sure your ONT isn't doing any routing or wifi. I believe it may have built in router and wifi.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@BadgerMe wrote:Thanks for the direction.
