Reply
Orbi RBR50 Solid White RIng
JeffreyRoach
Follower
Powered the Orbi off and on this morning and the ring turned solid white. Rings on the two satellites were majenta. I read to do a factory reset and run through the setup again, but it won't factory reset. I held the button in for 2 minutes and nothing happened. I fear it's dead in the water. Any suggestions?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
Chuck_M
Mentor
Re: Orbi RBR50 Solid White RIng
I would unplug everything from Orbi and wait 5 mins.
The plug it in to power only and do this process:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
If that doesnt work, I am afraid you may have a boat anchor.
My Equipment: Cox Cable (350Mb/35Mb), Orbi AX6000 (RBR850, 3 x RBS850) (2xWired backhaul), NG GS116PP Gigabit Smart Switch, Synology DS1019+ NAS
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 789 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
