Orbi WiFi 7 RBE973
Reply
Orbi RBR50 Time not updating after British Summer Time change
jwilliamsm3
I have the Orbi RBR50 system with 1 satellite, running latest firmware V2.5.1.8
I checked the time settings and it hadn't updated by going forward 1 hour.
Automatically adjust for daylight savings time was ticked, and my time zone of GMT Dublin, Edinburgh, Lisbon, London selected.
I checked and unchecked, rebooted, tried a different NTP server but couldn't get the time to update.
Only was i managed it wa by unticking auto adjust daylight savings, and selecting the next GMT +1 time for Amsterdam/Berlin etc
Any fix availiable?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Accepted Solutions
Guru
Re: Orbi RBR50 Time not updating after British Summer Time change
Disable DST on the RBR and set the correct time zone...reboot..the time should be correct...
Message 2 of 4
All Replies
Guru
Message 2 of 4
jwilliamsm3
thanks, even though that didn't fix it, i just reselected auto adjust for daylight savings again after the reboot, clicked apply and it worked. wouldn't do that early hours this morning though
Message 3 of 4
Guru
Ok, thanks for letting us know the process. Hopefully will help others.
Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 658 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
